This topic is sourced from common support emails:
How do I remove my SAInt trial license?
SAInt uses CodeMeter for its licensing. Other software also uses CodeMeter for its licensing, so make sure that you are careful about what license you want to remove!
To remove a SAInt license:
Step 1: Locate the serial number of your license: Open CodeMeter Control Center → click on the license you want to remove → note the “Serial” number
Step 2: Open CodeMeter Command Prompt: Start Menu → All Programs → CodeMeter → Tools → CodeMeter Command Prompt
Step 3a: If the license Serial number starts with 130, you have a soft license, run: cmu32.exe --delete-cmact-license --serial <license_serial_number>
Step 3b: If the license Serial number starts with 140, you have a cloud license, run: cmu32.exe --delete-cmcloud-credentials --serial <license_serial_number>
