When I define PSETPRCDEF values for PV and wind generators (for example, the default values are 2000 at creation), the generators follow the input profiles. However, if I set them to 0, they over-generate (exceeding their PMAXDEF values) and the PV units even generate at night. How can I resolve this issue?
Iām assuming you have defined a PSET event with a profile for this PV object, but Iāve included some follow up questions below. The PSETPRC value is the āpriceā for curtailing generation, i.e. for the power output P to be less than the scheduled power output PSET. When the value of PSETPRC is 0, then the power output can be anywhere between 0 and PSET. PMAXDEF should create a hard limit above which the unit cannot generate, unless you also change the value of PMAXPRC.
If you donāt mind, Iād like to ask a few more questions to understand how you are configuring your model.
What is the value of the following default event value properties?
PMAXDEF
PMINDEF
PSETPRCDEF
Is the scenario you are referring to a production cost model (DCUCOPF)?
Are there any of the following events in this scenario?
Thanks for your reply. The issue has been resolved. I noticed that both PMAXPRCDEF and PSETPRCDEF were set to 0. After changing PMAXPRCDEF to its default value (+Inf), the PV and wind generators active power were correctly derived from the capacity factor profiles.
