node-locator
Node Locator
Node Locator is a SAInt Python plugin that calculates and updates electric-network node coordinates.
Node Locator supports two coordinate workflows:
  1. CSV-provided workflow — a CSV supplies the fixed node coordinates used by Spring.
  2. SAInt-network workflow — when no CSV is supplied, existing nonzero ENET coordinates are fixed and nodes at (0, 0) are calculated.
The plugin currently supports:
  • Spring layout
  • Circular layout
  • Optional CSV-defined fixed locations
  • Existing SAInt coordinate anchors
Versions compatible with SAInt 3.9
SAInt Network File
Required
File type: .enet
The electric network file whose node coordinates will be processed.
Coordinate CSV File
Optional
File type: .csv
Required columns: Name, X, Y
Example:
Name,X,Y
N1,-104.9903,39.7392
N2,-105.2705,40.0150
Column Description
Name SAInt node name. It must match a node in the ENET.
X Fixed X coordinate.
Y Fixed Y coordinate.
CSV rules:
  • Valid rows become candidate fixed locations.
  • Node names are validated against the ENET.
  • Invalid rows are excluded and reported.
  • In CSV mode, existing SAInt coordinates are not automatically added as anchors.
  • CSV coordinates are written into the copied ENET.
Layout Input Options
Spring Layout
Spring is a force-directed NetworkX layout. Connected nodes attract one another, nodes repel one another, and the algorithm iteratively moves calculated nodes toward a stable arrangement.
Behavior:
  • Fixed locations remain anchored.
  • Nodes without fixed coordinates are positioned relative to the network topology and fixed anchors.
  • Final calculated coordinates are written to the copied ENET.
Settings:
  • Seed — controls the pseudo-random starting state and improves repeatability.
  • Iterations — controls how many force-directed iterations are performed.
  • K factor — controls preferred node spacing.
  • Coordinate padding — adds room around fixed-coordinate bounds.
Circular Layout
Circular places every node around a circle.
Behavior:
  • Every node is recalculated.
  • CSV anchors are ignored.
  • Existing SAInt coordinates are ignored.
  • All final coordinates are written to the copied ENET.
Settings:
  • Circular scale — controls the radius or overall size of the layout.
Advanced Inputs (Optional)
  • SAInt API DLL Path
    Full path to the SAInt API DLL. Defaults to {SAIntInstallPath}``//SAInt-API.dll.
  • Output Directory
    Full path to the directory where the copied and updated SAInt network, JSON results, copied coordinate CSV, and HTML report will be saved. Defaults to {SAIntDocPath}//PluginOutput.
  • Set Network CRS to None
    Optional setting that changes the copied ENET network CRS type to NONE.
  • Logging Level
    Controls the amount of diagnostic information produced by the plugin.
  • Results Filename
    Base name for the JSON output without .json extension. Defaults to results.
  • Report Filename
    Base name for the HTML output without .html extension. If left blank, the report name is derived from the output-folder name.
Installation
What You Need
  • The latest version of SAInt installed.
  • The packaged Node Locator plugin.
A packaged plugin will typically contain:
node-locator.plugin/
├── main.exe
├── form.yaml
├── icon.svg
└── _internal/
Installing or Selecting the Plugin in SAInt
  1. Open the SAInt GUI.
  2. Go to Tools → Plugin Settings → Install Plugin.
  3. Select the folder containing the Node Locator plugin.
  4. Select Apply & Exit.
Running the Plugin
  2. Go to Tools and select the installed Node Locator plugin.
  3. Complete the plugin form:
    • Select the required SAInt network file (.enet).
    • Optionally select a coordinate CSV file.
    • Choose the layout type: spring or circular.
    • Configure the settings for the selected layout.
    • Select the output directory.
  4. Execute the plugin.
Understanding the Output
Typical output:
ENET39_Spring/
├── ENET39_spring_csv.enet
├── fixed_locations.csv             # Only when a CSV was supplied
├── results.json
└── ENET39_Spring.html
File Description
Updated copied .enet Copied network containing final coordinates.
Copied .csv Coordinate source used for the run, present only in CSV mode.
results.json Structured inputs, settings, statuses, coordinates, and SAInt write outcomes.
{output-folder-name}.html Human-readable report with tables and embedded Sigma graph.
Results
The JSON includes:
  • Plugin name and version
  • Copied input paths
  • Selected layout and settings
  • Fixed-location parse statuses
  • Fixed-location validation statuses
  • Fixed locations
  • Layout coordinates
  • Node update statuses
  • SAInt write results
  • Final updated nodes
In no-CSV mode:
"fixed_location_parse_statuses": []
In CSV mode, this list may contain parsing warnings or errors.
HTML Report
The report includes:
  • Run and input summary
  • Layout settings
  • Fixed-location information
  • Validation and status tables
  • Node update results
  • Embedded Sigma graph
Coordinate Workflows
Workflow 1: CSV-Provided Coordinates
When a CSV is supplied:
  • The CSV is the only source of fixed locations.
  • Valid CSV nodes become fixed Spring anchors.
  • Existing SAInt coordinates do not create additional anchors.
  • Nodes not listed in the CSV are calculated.
  • CSV-fixed coordinates are written into the copied ENET.
  • Invalid CSV rows and unmatched node names are reported.
Example:
Node Existing ENET coordinate Listed in CSV Result
A (100, 200) No Calculated
B (0, 0) Yes Fixed from CSV
C (300, 400) Yes Fixed from CSV
D (0, 0) No Calculated
Use this workflow when a trusted external coordinate source should be authoritative.
Workflow 2: Existing SAInt Network Coordinates
When no CSV is supplied:
  • Existing ENET coordinates are inspected.
  • Nodes with coordinates other than (0, 0) become fixed Spring anchors.
  • Nodes at exactly (0, 0) are treated as unknown.
  • Existing fixed coordinates remain unchanged.
  • Calculated coordinates are written into the copied ENET.
Example:
Node Existing ENET coordinate Result
A (100, 200) Fixed
B (0, 0) Calculated
C (-70, 42) Fixed
D (0, 0) Calculated
v0.1.1
  • Initial Node Locator implementation.
  • Added CSV-provided and SAInt-network coordinate workflows.
  • Added Spring and Circular layouts.
  • Added coordinate write reconciliation.
  • Added copied ENET output.
  • Added JSON and HTML reports.
  • Added embedded Sigma graph.
  • Added unit, snapshot, and live integration tests.
