How to model ramping for Nuclear Reactors
How can I effectively model ramping for small modular nuclear reactors?
Most of the figures I find online are given in % Power/min.
Are the fields I need to populate for this “MaxDownRampDef” and “MaxUpRampDef”?
I tried to enter “FGEN.SMR.PMAXDEF.[kW] * 0.10” to model a 10% ramp rate for each of these fields, however they will not permit entry of anything other than numerical values.
You found the correct property!
I think I can clear up your confusion with few quick notes on Default Event Values vs. Events.
Default Event Values (e.g., MaxUpRampDef):
  • Defined at the network level
  • Must be a numeric value (e.g., 0, 10, 2.75, etc.)
  • Are used in all relevant scenarios unless they are superceded by an Event
Events (e.g., MaxUpRamp):
  • Defined at the scenario level
  • Can be numeric, or can be a Value Expression (e.g., “FGEN.SMR.PMAXDEF.[kW] * 0.10”)
  • Are used in the scenario within which they are defined
Pro tip: Value Expressions can reference Default Event Values (e.g., “FGEN.SMR.PMAXDEF.[kW] * 0.10”) or values after the processing of other Events (e.g., “FGEN.SMR.PMAX.[kW] * 0.10”). This choice is up to the user. Referencing Default Event Values will have a small performance benefit and is generally recommended, but referencing the Event Value directly may be necessary when coordinating multiple changes across different scenarios.
