A simple plugin that translates power system data from .raw files to SAInt format.
Download it here: dot-raw-to-saint-plugin-v0.1.0.zip (114.5 MB)
This plugin translates power system data from .raw files to SAInt format.
Multi-Component Translation: Supports translation of all major power system components:
- ZONE
- BUS
- GENERATOR
- LOAD
- TRANSFORMER
- BRANCH
- SWITCHING DEVICE
- FIXED AND SWITCHED SHUNT DEVICES
Version Compatibility: Currently supports
.rawfile versions 33 and 35. Additional versions will be supported in future updates. -
Reporting: Generates comparison plots to validate translation accuracy.
Synthetic Coordinate Generation: Optionally generates synthetic BUS coordinates for network visualization in SAInt GUI.
Path to RAW File
Full path to the*.rawfile. -
RAW Version
Version number of the*.rawfile (e.g., 33 or 35). -
Headers in RAW File
Specify whether the*.rawfile includes column headers. -
Generate Synthetic Coordinates
Option to generate synthetic bus coordinates for visualization in SAInt. -
Output Directory
Full path to the directory where the translated SAInt network, scenario, and condition files will be saved.
If the network successfully converges in SAInt, validation plots will also be saved here.
Advanced Inputs (Optional)
Network Name
Name for the translated SAInt network. Default is"DOT_RAW_NETWORK". -
Parse RAW File
Set toTrueto parse the.rawdata into readable CSV files. -
Translate Data
Set toTrueto convert parsed data into SAInt-compatible Excel import files. -
Run Simulation for Validation
Set toTrueto generate native SAInt network and scenario files and run a SteadyACPF simulation for validation. -
Generate Validation Report
Set toTrueto create validation plots comparing results from the.rawfile and the SAInt simulation. -
Save Output Files
Set toTrueto save all generated SAInt files and validation plots.
Example with IEEE 118 Bus System
The following is an example of running the plugin with the IEEE 118 Bus System.
What You Will Need
To start, please download:
- The latest version of SAInt.
- The IEEE 118-Bus System
.rawdataset, downloadable from: here - This DOT-RAW to SAInt plugin. Unzip it and note the location of the download.
dot-raw-to-saint-plugin/
├── main.exe
├── form.yaml
└── (other files)
Running the PlugIn
- Open SAInt GUI
- Select Plugin In SAInt: Tools → Plugin → Select (select the folder containing the plugin)
- Execute Plugin: Tools → Plugin → Execute
Fill out the form with the following required inputs:
- Path to RAW File: ./path to your .raw file.
- RAW Version: 33
- Headers in RAW File: True
- Generate Synthetic Coordinates: True
- Output Directory: ./path to your output directory
Expand the advanced inputs section in the form and write “IEEE_118” in the Network Name input.
Understanding the Output
In the specified Output Directory, the following files will be created:
- SAInt native files:
IEEE_118.enet: SAInt network fileacpf.esce: Scenario fileacpf.econ: Scenario condition file
- Logs
info.log: Contains logs of the translation operations.
- SAInt network Excel
network.xlsx: SAInt network import Excel file
- Reporting
voltage_comparison.html: Comparison plot of voltage magnitudes and voltage angles.branch_power_flow_comparison.html: Comparison plot of line active, reactive, and apparent power flow.
- parsed: Contains raw-to-CSV parsed data for reference.
