I noticed that I cannot edit certain parameters in my network while I have a scenario open (for example, deleting an external, changing the capacity or name of an external, etc.). If I close the scenario, edit these parameters, and then re-open the scenario, what are the effects this has on the behavior of the scenario?
Great observation! Hopefully I can clarify the behavior here for you.
For example, if you close your scenario, rename an object, and then open the scenario, any events attached to that object will still work just fine. This is because the events are linked to the object’s Unique Identifier (UID) rather than the Name. You’ll notice that the UID is never editable - it is created when an object is created and is never changed. This way, this linkages between the network and its scenarios are more stable.
